Hello all, I am new here, but I will try to explain my problem as best as I can.
I have recently put together a system using the following components:
Asus M4N98TD EVO Motherboard
gskill F3-12800CL8D-4GBRM (2x2GB DDR3 1600) (listed on the mobo QVL)
AMD Phenom II 965 BE
EVGA GTX260
Windows pro 7 64bit
Ever since I assembled this system last week, I have been unable to run the Ram in dual channel. Everytime I run both sticks I am getting Bad_Pool_Header, PFN List Corrupt, Memory management etc. errors almost immediately.
I have run windows memory diagnostic with both sticks and it freezes on first pass on extended test at 21%
Running memtest 86+ will display lots of errors with dual channel operation as well.
However, when I am running just one stick of ram in any slot, I can run memtest and windows memory diagnostic, and the OS all night long with no errors whatsoever. And I haven't even tried to run these sticks any higher than 1333 speed. I tried adjusting the ram timings and voltages manually to 1.6v at 9-9-9-24-4-33-10-5 to no avail.
Another funny thing is when running memtest with one stick in slot a1 or a2 (first black and blue) memtest says it is a speed of ddr 1333, but in b1 or b2, the detected speed is ddr 400.
Any ideas on what the hell is wrong? I can't tell if it is a ram problem, cpu memory controller problem, motherboard problem, or maybe there is something I am simply missing on my adjustments. I would certainly appreciate any help you could offer.
Thanks,
Jason
P.S. By the way, I have already updated the BIOS to the current version and am using the current NVIDIA driver for the GPU. Also, sometimes if the system has been on for a long time, it will eventually become a bit more stable running two sticks (as in it may run for a little while without BSOD). But after leaving it off for a few hours It immediately becomes unstable upon startup.
EVGA GTX260
Windows pro 7 64bit
Thanks,
Jason
