I am experiencing strange behaviour with my machine: spontaneous reboots, broken Zip-Archives while unzipping, and crashes like "xyz.exe doesn't work anymore".
My computer consists of:
Asrock 890FX Deluxe3,
Phenom II 1055T,
some Radeon 5850
and a total of 8G Ripjaws F3-10666CL7D-4GBRH (that's 4x2 GB Sticks).
Everything runs at stock settings besides bumping RAS/CAS-timings from 9 to 7 clocks (doesn't make any difference for the upcoming though)
In order to check the components, I've run Linx 0.6.4 and Intel Burn Test - both failed in short time due to errors.
So I tested all RAM-sticks one by one with memtest 086+: 3 were fine and one spills out errors:
Is that stick broken? Can it be rescued? And: In case of RMA - do you need both sticks of that kit or just the faulty one?
Thank you kindly,
d.
Phenom II 1055T,
some Radeon 5850
Thank you kindly,
d.
