Every cold boot a memory related bluescreen (4GB-Kit G-Skill PC3-12800U CL9)
  • Every cold boot a memory related bluescreen (4GB-Kit G-Skill PC3-12800U CL9)
    PFN_LIST_CORRUPT, PAGE_FAULT_IN_NON_PAGED_AREA and so on. Every morning I boot. I already did the following: Switched the mainboard, got new ram (gskill again, had ripjaws before), switched the GPU, switched the harddrive, installed different operation systems on differen't harddrives. The problem remains. I don't know if its that cold boot bug I keep hearing about, maybe the ram I bought after that had the same problem. I don't know what else it could be. I already set the timings like a gskill support member told me, it didn't help.
    The PC is well cooled and up to date. My mainboard is a revision 2 Gigabyte GA-890GPA-UD3H.
    Go ahead and send them in for new replacements and the new set should work better.
      Are you sure? Because I already got a new pair and it was exactly the same with them. Is that possible?
      Also, do I have to send it somewhere else when I live in Germany?
        Does work fine after you hard reset the computer? Or does it always blue screen?
          I get one bluescreen after it was off for around 8 hours (overnight), and when I then restart it works fine for the rest of the day, rebooting and everything.
            Send the memory in for new replacements and the new set should work better.
