Greetings,
Although I've built several systems, memory has never been an area I've felt over comfortable with. Now I'm having trouble with my memory setup and would really appreciate some help.
I have the Asus Rampage Extreme 3 mobo with an i7-960 cpu, windows 7 Professional 64 bit. I purchased 2 sets of (2x2GB) F3-16000CL6D-4GBPIS and I'm having the following problems.
* First, the mobo/bios will only show 4GB. Windows also will only show 4 GB while CPU-z shows all 8GB.
* The second issue is I am having trouble setting the speed. Although I've gotten it up to 1600, I cannot get 1866 to work. Nor does the bios allow for setting it to 2000.
The good news is that I am still within my return window with Newegg if I need to get a different set of memory (It would still be G.Skill.
) Did I buy the wrong memory?
As I mentioned before, memory is not a strong skill for me so please be specific as you can be.
Thanks....
) Did I buy the wrong memory? As I mentioned before, memory is not a strong skill for me so please be specific as you can be.
Thanks....
