NF980-65 and memory OC
  • NF980-65 and memory OC
    I have been trying my hardest to OC my memory on this board above 1600Mhz..And know matter what I do..I can not get it to boot with the memory over 1600Mhz...And I have the ratio for the memory at 1:4 to get it to the 1600Mhz..
    I have tired
    OCing the FSB
    Adjusting the voltge to the NB, CPU, Memory
    Adjusting the timings to the memory
    I can OC the CPU and HT and NB stable
    CPU to 4100Ghz stable
    HT to 2600 stable
    But can't get my memory pass 1600
    anyone have any clues
    What CPU do you have? You need to overclock the NB Frequency to 2200MHz, and CPU-NB Voltage +0.1V.
      my bad
      AMD X6 1090T..I have it OC right now at 4000Ghz..and my memory is at 1666..but would like it at 2000mhz..i have tired the NB voltge OC and setting it to 2200 or 2400 and 2600..none of them was stable
        Post pictures of your best setting and we can see what's going on. Make sure you are adjusting the proper voltages. NB Voltage is not the same as CPU-NB Voltage. CPU VDD is not the same as CPU Voltage. etc.
