I have purchased 2 kits of the DDR# triple channel G skill RipJaw 2000 mhz memory (part # F3-16000CL9T-6GBRH) for a total of 12 GB. I have setup the timings as suggested at 9 9 9 27 and dram voltage is at 1.60. My cpu is the i7 980x and I have OC'd it to 4.2 ghz. Cpu voltage is 1.375, fsb is at 200 and core multi is at 21. I have left the QPI voltage at its recommended setting. My motherboard is the Asus Rampage II Extreme with the latest BIOS.
I am able to boot into windows without any issues. If I run prime95, I get a test failure within the first 1 minute on one of the first 3 tests.. I stop the tests and the system is still running (no BSOD). If I lower the clock speed to 1600 mhz for the ram, I am able to run prime95 without any issues.. Would you have any recommendations as to where I would go next to get the ram to run stable in prime95 at 2000 mhz?
Just to recap:
i7 980x cpu OC'd to 4.2 ghz, voltage is at 1.375
12 gb g skill ddr3 triple channel ram, timings set to 9 9 9 27 voltage at 1.6
asus rampage II extreme motherboard
Any help would be appreciated thanks!
Chad
Just to recap:
Chad
