Which memory for Overclocking?
  • Which memory for Overclocking?
    Im interested in buying Gigabyte X58-UD7 motherboard, Intel i7 930 CPU and G skill memory. I eventually want to overclock the CPU to around 4ghz and was wondering what memory is best? Is it better to go for high frequency (2000mhz) or low latency (CL7)? I am considering buying Ripjaw F3-1600CL9T 6gb. Is this a good choice?
    If you plan to overclock, then high memory frequency can be utilized, but you will need an aftermarket CPU cooler.
    The RipJaws is a good choice especially for the low price. But, we do have many other high performance DDR3-2000 modules.
    Take a look at this thread, it is exactly what you want to do:
    http://www.gskill.us/forum/showthrea...highlight=x58a
      I've considered the Tridents (as in the link you described) but unfortunately the tall heat spreaders are not compatible with the cpu cooler i wish to buy (Noctua NH D14)
        Oh I know, I just want you to see the BIOS settings. Your settings will be similar too, so it's good to see an example.
