I've recently purchased a computer with the following specs:
Motherboard: ASUS P7P55D-E PRO (BIOS version 0610)
Memory: 2 kits of F3-12800CL9D-4GBRL (8 gb, 4 DIMMs total)
CPU: Intel Core i7 860
OS: Windows 7 Home Premium
I've been occasionally (at a rate of 1-2 times per day) getting BSODs in Windows 7 (especially within minutes after loading into Windows from a cold boot) with the following bug check strings:
0x0A IRQL_NOT_LESS_OR_EQUAL
0X7E SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
0X1A MEMORY_MANAGEMENT
0X4A IRQL_GT_ZERO_AT_SYETEM_SERVICE
0X1E KMODE_EXCEPTION_NOT_HANDLED
0X3B SYSTEM_SERVICE_EXCEPTION
0XD1 DRIVER_IRQL_NOT_LESS_OR_EQUAL
These crashes occured with Ntfs.sys and ntoskrnl.exe, and I suspect it is due to the memory settings. Memtest86+ detected no errors after 9 passes with the below settings.
I'm using the factory settings for the BIOS (although I've set the DRAM freq. to DDR3-1333MHz which is probably the same as the factory defaults). It's also my first time running a system with all DIMM slots filled, so I don't know if e.g. the voltages will have to be tweaked.
Here's the BIOS settings and what CPU-Z sees:
My goal is to run a stable system with minimal (or no) overclocking. I'm quite the novice when it comes to managing memory settings so I hope I can find the help I need in these forums. Many thanks to those who contribute to this thread!
Cheers! XD
Josh
Ai Tweaker
CPU Level Up – [Auto]
Ai Overclock Tuner – [Auto]
Intel(R) SpeedStep(TM) Tech – [Enabled]
Intel(R) TurboMode Tech – [Enabled]
Xtreme Phase Full Power Mode – [Auto]
DRAM Frequency – [DDR3-1333MHz]
QPI Frequency – [Auto]
ASUS/3rd Party UI Priority – [ASUS Utility]
OC Tuner – [Turbo Profile]
DRAM Timing Control *every parameter set to [Auto]*
1st Information: 9-9-9-24-4-74-10-7-20
2nd Information: 2N-52-53
3rd Information: 5-5-16-10-10-10-7-6-4-7-7-4
CPU Differential Amplitude – [Auto]
CPU Clock Skew – [Auto]
CPU Voltage Mode – [Offset]
Offset Voltage – [Auto]
Current CPU Core Voltage – [1.080V]
IMC Voltage – [Auto]
Current IMC Voltage – [1.118V]
DRAM Voltage – [Auto]
Current DRAM Voltage – [1.550V]
CPU PLL Voltage - [Auto]
Current CPU PLL Voltage – [1.803V]
PCH Voltage – [Auto]
Current PCH Voltage – [1.050V]
DRAM DATA REF Voltage on CHA – [Auto]
DRAM DATA REF Voltage on CHB – [Auto]
Load-Line Calibration – [Auto]
CPU Spread Spectrum – [Auto]
PCIE Spread Spectrum – [Auto]
Advanced
CPU Configuration
CPU Ratio Setting – [Auto]
C1E Support – [Enabled]
Hardware Prefetcher – [Enabled]
Adjacent Catch Line Prefetch – [Enabled]
Max CPUID Value Limit – [Disabled]
Intel(R) Virtualization Tech – [Enabled]
CPU TM Function – [Enabled]
Execute-Disable Bit Capability – [Enabled]
Intel(R) HT Technology – [Enabled]
Active Processor Cores – [All]
A20M – [Disabled]
Intel(R) C-STATE Tech – [Enabled]
C State package limit setting – [Auto]
Advanced
CPU Configuration
A20M – [Disabled]
Cheers! XD
Josh
