i7 930 F3-16000CL9T-6GBRH ga-x58a-udr3
  • i7 930 F3-16000CL9T-6GBRH ga-x58a-udr3
    New build, not looking to OC. Looking for safest BIOS settings to run RAM safely at 2000 Mhz. MOBO v 1.0 BIOS rev F5.
    Regards,
    Paul
    Many guides around here for this setup.
    http://www.gskill.us/forum/showthrea...highlight=x58a
    Should look something like this:
    CPU Clock Ratio - 17x for 2.8GHz
    QPI Link Speed - AUTO
    Base Clock Control - Enabled
    BCLK Frequency - 167
    System Memory Multiplier - 12
    Uncore & QPI Features
    Uncore Frequency - 4008
    CAS Latency Time - 9
    tRCD - 9
    tRP - 9
    tRAS - 27
    Enter these for the other three as well.
    Channel A Timing Settings
    Advanced Timings
    Command Rate - 2
    Advanced Voltage Control
    Load-Line Calibration - Disabled
    CPU Vcore - 1.32V
    QPI/VTT Voltage - 1.60V
    DRAM Voltage - 1.600V
    Rest to AUTO
      Did you manage to get the sticks running at 2000 with the Motherboard ?
        Do a search for "x58a", many people use this combination. =)
          Almost
          I went through all the suggestions but running at 2000 just wasn't stable under stress. The best I could get was 1716. Not too shabby, but not quite as advertised.
            You can reduce timings if you're only at DDR3-1716. 8-8-8-24 will be stable, but you can try lowering to 7-7-7-21 for max performance.
