I would like to overclock my ram. As it stands I don't really want to go out and buy a massive CPU cooler and OC my cpu, but if the only way to OC the ram is to OC the cpu I may consider it.
Sorry for the noob question but I haven't got much experience with overclocking and I would rather just try my luck here first before I start to fiddle by myself.
Specs:
Phenom II x6 1090T
F3-17600CL7D-4GBPIS
GA-890FXA-UD7
The mobo supports up to 1866mhz (OC) and I am currently running the ram dual channel at the stock speed of 1600mhz (or 800 coz its dual channel)
What timings, V's, etc do I have to change to get it to 1866.
FYI My timings atm that cpu-z tell me are:
CL-11
tRCD-11
tRP-11
tRAS-29
tRC-40
CR-1T
I've got no idea what the above means but thought I would list anyway.
I figured if the ram is capable of getting to 2200 then I may *** well run it at the mobo's max supported speed.
Any help would be greatly appreciated and thank you for your time.
Specs:
Phenom II x6 1090T
F3-17600CL7D-4GBPIS
GA-890FXA-UD7
CL-11
tRCD-11
tRP-11
tRAS-29
tRC-40
CR-1T
