CPU: AMD Athlon II X4 630 Propus 2.8GHz
Mobo: GIGABYTE GA-870A-UD3 AM3 AMD 870
RAM: G.Skill Ripjaws F3-12800CL9D-4GBRL
Let me start out by saying I'm only a novice builder
This is a brand new system that loaded up fine with just one BSOD the other day.
When I ran some memtests I couldn't get it to pass without errors. I tried setting it to 1066/1333/1600 and it failed all three times. when set to 1600 the system would just reset even with a little bump to the NB volt (+.1).
When I tested each of the 2GB sticks alone they both made it through 4 passes with no errors, so the sticks are good. Had my timings set to 9-9-9-24-2 for all testing.
Looking to learn, this is my first AMD build as well as first time playing with DDR3.
Thanks!
Thanks!
