Asrock 890GX compatibility
  • Asrock 890GX compatibility
    Hi everyone. This is my first post. I have a Asrock 890GX extreme 3 board on the way which Supports Dual Channel DDR3 1800(OC). I was wondering if anyone know if any of the ram below can run on the board?
    G-Skill 4GB Ripjaws DDR3 PC16000-2000Mhz Cas9 Kit - F3-16000CL9D-4GBRH
    G-Skill 4GB Trident DDR3 PC16000-2000Mhz Cas9 Kit - F3-16000CL9D-4GBTD
    I will probably buy a Phenom X2 555 and later a Phenom X6, which can handle ram speeds up to 2000MHz. So be nice to have the ram without having to buy different sticks for Phenom X6.
    thanks!
    Should have no problems at all.
