F3-12800CL7 on ASUS P5E3 Pro
  • F3-12800CL7 on ASUS P5E3 Pro
    Memory: 2x2GB G-Skill Ripjaws F3-12800CL7
    Mainboard: ASUS P5E3 Pro, BIOS 0505
    CPU: Intel Q8300
    OS: Win7 32bit
    BIOS-Settings are to defaults (auto).
    I get a lot of random BSOD:
    I made a memtest and it shows me errors.
    What are the correct BIOS settings to get a stable system?
    Actual settings:
    Thanks!
    No idea ?
      Manually set the frequency, timings, and voltage, then retest.
        To which values?
          The ones on your memory, or memory packaging. If you have the RipJaws RH Series, it should be 7-7-7-21. If you have the RM Series, it should be 7-8-7-24.
            I've tried 7-8-7-24 with DRAM voltage 1.60V (written on the sticker) but still get errors with memtest...
              Test them one at a time to see if one module may be defective.
                I've tested them one by one without any errors (~24h tests).
                As soon as i put both together (dual channel), i get errors after e view minutes...
                Whats next?
                  Now i've got a stable system using following settings with dual channel:
                  CPU Ratio Setting: 07.5
                  DRAM Frequency: DDR3-1333Mhz
                  DRAM Voltage: 1.60
                  Well, it's not FSB400, but better than BSOD all the time...
                    You may need to increase FSB Termination Voltage to stabilize CPU FSB 400.
