I have spent the better part of 2 days trying various settings that I have found here on the GSkill forums and on the Asus forums. However, i have not had any luck getting a stable build. I have had tons of BSOD and i have re-installed Windows 7 64Bit a thousand times.
My question is this: What settings are stable for this memory to work with this motherboard. I know someone out there has this same setup and has done this before. I dont want to reinvent the wheel either.
Please help, I am lost and going in circles. All I would like to do is have a stable 24/7 build.
System Details:
i7 920 CPU
ASUS p6x58D Premium (Bios 808)
G.SKILL Ripjaws Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000)
Current BIOS Settings
Ai Tweaker
Target CPU Frequency: 2660MHz
Target DRAM Frequency: 1066MHz
Default
Ai Overclock Tuner [Auto]
CPU Ration Setting [Auto]
Intel ? SpeedStep ? Tech [Enabled]
Intel ? TurboMode Tech [Enabled]
Xtreme Phase Full Power Mode [Enabled]
DRAM Frequency [Auto]
UCLK Frequency [Auto]
QPI Link Data Rate [Auto]
CPU Voltage Control [Manual]
CPU Voltage [Auto]
CPU PLL Voltage [Auto]
QPI/DRAM Core Voltage [Auto]
IOH Voltage [Auto]
IOH PCIE Voltage [Auto]
ICH Voltage [Auto]
ICH PCIE Voltage [Auto]
DRAM Bus Voltage [Auto]
DRAM DATA REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM DATA REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
Load-Line Calibration [Auto]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
CPU Spread Spectrum [Auto]
IOH Clock Skew [Auto]
PCIE Spread Spectrum [Auto]
DRAM Timing Control (Sub Menu)
1st Information: 8-8-8-20-4-59-8-6-20-0
DRAM CAS# Latency [Auto]
DRAM RAS# PRE Time [Auto]
DRAM RAS# ACT Time [Auto]
DRAM RAS# to RAS# Delay [Auto]
DRAM REF Cycle Time [Auto]
DRAM WRITE Recovery Time [Auto]
DRAM READ to PRE Time [Auto]
DRAM FOUR ACT WIN Time [Auto]
DRAM Back-To-Back CAS# Delay [Auto]
2nd Information: 1N-51-53-53
DRAM Timing Mode [Auto]
DRAM Round Trip Latency on CHA [Auto]
DRAM Round Trip Latency on CHB [Auto]
DRAM Round Trip Latency on CHC [Auto]
3rd Information: 5-5-14-10-10-10-7-6-4-7-7-4
DRAM WRITE to Read Delay (DD) [Auto]
DRAM WRITE to Read Delay (DR) [Auto]
DRAM WRITE to Read Delay (SR) [Auto]
DRAM READ to WRITE Delay (DD) [Auto]
DRAM READ to WRITE Delay (DR) [Auto]
DRAM READ to WRITE Delay (SR) [Auto]
DRAM READ to READ Delay (DD) [Auto]
DRAM READ to READ Delay (DR) [Auto]
DRAM READ to READ Delay (SR) [Auto]
DRAM WRITE to WRITE Delay (DD) [Auto]
DRAM WRITE to WRITE Delay (DR) [Auto]
DRAM WRITE to WRITE Delay (SR) [Auto]
System Details:
i7 920 CPU
Ai Tweaker
Default
CPU Voltage [Auto]
IOH Voltage [Auto]
ICH Voltage [Auto]
