Ga-ma785gmt-ud2h f6 & f3-12800cl9d-4gbnq
  • Ga-ma785gmt-ud2h f6 & f3-12800cl9d-4gbnq
    CPU: AMD Phenom II X4 965 125watt C3
    MOBO: GA-MA785GMT-UD2H F6
    RAM: F3-12800CL9D-4GBNQ (8GB)
    I am in need of help as my new system build has been crashing and running unstable with the memory timings I have adjusted them from the default timings. My timings were initially defaulted at 11-11-11-29 on 1333 (which actually ran stable), however from what i understand, these are supposed to be running at 9-9-9-24 at 1600 (which is what i manually changed to). Here are screen shots from my bios as well as CPUZ. What should the correct timings be? Your help is greatly appreciated!
    Everything looks good so far. Set tRFC 0, 2, 1, 3, to 160ns. Northbridge Volt Control to 1.40V.
    Let me know how that goes.
