I have this configuration :
- Asus Rampage II Extreme
- Intel Core I7 960 r?vision D0
- [ Ripjaws ] F3-16000CL9T-3GBRH / F3-16000CL9T-6GBRH
I have read this post, http://www.gskill.us/forum/showthread.php?t=1166 and I have test it.
But when the PC start, the PC doesn't boot, I stop on CPU. I Change two option (red color) for my memory.
Can you help me please ?
See you later.
Seb2142
PS : sorry for my english, I'm french.
AI overclock - manual
OC from CPU level up - auto
OC from Memory level up - DDR3-2000
CPU Ratio setting - 18 for 3.6GHz
CPU Turbo Power Limit - disable
CPU configuration
CPU Ratio Setting - whichever you chose above
C1E Support - disable
Hardware prefetcher - enable
Adjacent Cache line prefetcher - enable
Intel Virtualization tech - disabled
CPU TM Function - disable
Execute Disabled bit - disabled
Intel HT Technology - disable
Active Processor Cores - all
A20M - disabled
Intel C-STATE tech - disabled
BCLK frequency - 200
PCIE frequency - 100
DRAM frequency - 2000 MHz
UCLK frequency - 4000 MHz
QPI frequency - auto
Dram Timing Control
DRAM CAS# Latency - 9
DRAM RAS# to CAS# Delay - 9
DRAM RAS# PRE Time - 9
DRAM RAS# ACT Time - 27
DRAM REF Cycle Time - 72
DRAM Timing Mode - 2N
All others can be on AUTO
EPU II Phase Control - Full Phase
Load-line calibration - enable
CPU differential amplitude - auto
Extreme OV - disabled
CPU voltage - 1.32V
CPU PLL voltage - 1.85V
QPI-DRAM voltage - 1.55V
IOH voltage - 1.35V
IOH PCIE voltage - 1.60V
ICH voltage- 1.20V
ICH PCIE voltage - 1.60V
DRAM Bus voltage 1.65V
CPU spread spectrum - disabled
PCIE spectrum - disabled
CPU clock skew - auto
IOH clock skew - auto
See you later.
Seb2142
CPU configuration
A20M - disabled
Dram Timing Control
CPU voltage - 1.32V
IOH voltage - 1.35V
ICH voltage- 1.20V
