Problems with GSkill Trident 16000 2000MHZ
  • Problems with GSkill Trident 16000 2000MHZ
    As many people have posted i cant reach the announced 2000MHZ frequency i used the bios specs posted in the forum but my pc wont boot it stays locked any help would be appreciated my systems specs are:
    Intel i7 920
    Corsair Modular 1000Wtts
    Asus Rampage Gene II
    Gskill Trident 16000 2000MHZ 3x2
    Asus Geforce GTX 285
    WD Velociraptor 300Gb
    Thanks in advance.
    Try these settings:
    AI overclock - manual
    CPU Ratio setting - 21
    CPU Turbo Power Limit - disable
    CPU configuration
    CPU Ratio Setting - 21
    C1E Support - disable
    Hardware prefetcher - enable
    Adjacent Cache line prefetcher - enable
    Intel Virtualization tech - disabled
    CPU TM Function - disable
    Execute Disabled bit - disabled
    Intel HT Technology - disable
    Active Processor Cores - all
    A20M - disabled
    Intel C-STATE tech - disabled
    BCLK frequency - 143
    PCIE frequency - 100
    DRAM frequency - 2002 MHz
    UCLK frequency - 4004 MHz
    QPI frequency - auto
    Dram Timing Control
    DRAM CAS# Latency - 9
    DRAM RAS# to CAS# Delay - 9
    DRAM RAS# PRE Time - 9
    DRAM RAS# ACT Time - 24
    DRAM REF Cycle Time - 74
    DRAM Timing Mode - 2N
    All others can be on AUTO
    EPU II Phase Control - Full Phase
    Load-line calibration - enable
    CPU differential amplitude - auto
    Extreme OV - disabled
    CPU PLL voltage - 1.85V
    QPI-DRAM voltage - 1.60V
    DRAM Bus voltage 1.60V
