Hello GSKILL TECH Administrator and Other members of the forum,
This is my first time to experience the G Skill memory. However I have to say I am very disappointed with the ram because I?m having the same instability issues that many others are having.
My system is:
P7P55D-E Deluxe with the newest Bios 0711
F3-12800CL8D-4GBRM
i7-860
Power Supply TT Toughpower 750W
Ati Radeon 5870
The main problems I am facing now are
1. the memory sticks can not pass MemTest 4.0 memory stability test, 5% coverage will result 9 errors!! I have to stop there
2. when using winrar to unzip the .rar file, I will have a lot of CRC unmatched error messages, although the files are OK in other system.
I have these problems when I set AI Overclock Tuner to XMP, with everything else default (no overclocking on CPU)! I have already tried to adjust different memory settings in bios, with no success.
i.e.
AI Overclock Tuner - Manual
CPU Ratio Setting - 17.0 for 2.80GHz
BCLK Frequency - 160
DRAM Frequency - DDR3-1600MHz
DRAM Voltage - 1.60V
CPU PLL Voltage - 1.90V
DRAM Timing Control (submenu)
CAS Latency - 8
RAS to CAS Delay - 8
RAS PRE Time - 8
RAS ACT Time - 24
DRAM Timing Mode - 2N
All others can be AUTO
For this memory, which settings should I use? Or I have something bad indeed!?
Thanks a lot for your time!!! Really appreciate any helps!!
Fei
My system is:
F3-12800CL8D-4GBRM
i7-860
Ati Radeon 5870
i.e.
CAS Latency - 8
RAS PRE Time - 8
RAS ACT Time - 24
Fei
