Timings/Latency
  • Timings/Latency
    Good evening all, I have G skill Ripjaws CA 7 that here:
    http://benchmarkreviews.com/index.ph...=429&Itemid=67
    Here captures of screen of CPU-Z.
    http://www.hiboox.fr/go/images/infor...e3b60.png.html
    http://www.hiboox.fr/go/images/infor...4f7d5.png.html
    My rams does not function at their frequency of 800mhz. I tried to force the 800 MHz in the bios but blue screen with crysis. I thus applied the timing recommended by the site and change the Dram voltage but my pc don't boot.
    Which are the good adjustments to be carried out?
    PS: My MB is a ASRock M3A790GXH/128M AMD Socket AM3 DDR3 Motherboard
    Thank you in advance
    DRAM Frequency - DDR3-1600
    DRAM Timings - tCL 8 - tRCD 8 - tRP 8 - tRAS 24 - Command Rate 2
    DRAM Voltage 1.60V
    You have the CL8 not CL7, that is probably the reason why it did not work. Also, with this motherboard you can't operate DDR3-1600 CL7 anyway.
