Hello expert,
I have overclocked the i7 870 beyond 4GHz and now is running at 4.05GHz with the RAM at 2208MHz and XMP on. RAM voltage set at 1.66v, BCLK at 184 and Multiplier at x22. Core voltage at 1.36v (MAX. at 100% loaded).
I have been testing this setup in PRIME (with various voltage settings). At 1.36v MAX, core temps are around high 70c and low 80c in average. Every time the system runs pretty well before 1.25 to 1.5 hours and after that fatal error occurs (one or more workers stopped working).
I would like the system to run with trouble free at PRIME at least for 2 hours (if possible, higher CPU speed as well).
So G SKILL EXPERT, which setting is the best for my system?
Thanks!
spec -
i7 870
Gigabyte P55A-UD4P / BIO F8 (latest)
4 x 2GB G. Skill DDR3 2200MHz CL7-10-10-28
Crosair Hydro H50 push pull x 2 Noiseblocker M12-S3hs fans
Radeon HD5770 x 2 CF
Crosair HX750 power
2 x 1TB WD Black
LG 8X Blu Ray rewriter
Samsung 22X DVD rewriter
Lian Li PC-60FNW
Zalman ZM-MFC1 fan controller
Noiseblocker PK-1 fan x 2 (side fans) / Noiseblocker PK-2 fan x 1 (top fan)
Thanks!
spec -
i7 870
Crosair HX750 power
2 x 1TB WD Black
Lian Li PC-60FNW
