How to configuring RAM Timing at 7-8-7-24 of F3-12800CL7D-4GBRM
  • How to configuring RAM Timing at 7-8-7-24 of F3-12800CL7D-4GBRM
    Hello!
    I'm a newbie at configuring RAM Timings. Can anyone tell me the settings I need to change?
    I want RAM Timings at 7-8-7-24. I know ,If I turn on XMP, turbo boost will disable. How to configuring RAM Timings and turbo boost work together?
    CPU is i5-750 with orginal heatsink
    RAM is F3-12800CL7D-4GBRM
    Mobo is an ASUS P7P55D Pro.
    You can not use Turbo Boost with a memory frequency above DDR3-1333. So if you want Turbo Boost enabled, you will need to downclock the memory to DDR3-1333.
      I don't know if it's different with Intel, but my setup ran smoother with better benchmarks @ 8-8-8-24 than 7-8-7-24
