After months of crashes, reboots, and several re-installations of Windows 7 I have come to the conclusion that the RAM (OCZ Obsidian) I originally bought for the system is the root of all my problems.
I have a:
Gigabyte GA-P55-UD4P
Intel i5 750 Lynnfield Processor
(other less involved parts are a Sapphire 5770 Video Card and a OCZ Fatal1ty OCZ550FTY 550W power supply)
I have now purchased a memory which is on the ?Compatible Memory? list for the motherboard. I have purchased the G.Skill F3-12800CL9D-4GBNQ (2 x 2GB kit for 4GB)
I would like to know the recommend memory settings for this memory and motherboard combination. I am not overclocking. I would just like the system to run at spec and stable. I am not sure if I should just set it up to run with XMP and leave everything at auto, or are there some adjustments that are needed.
Thanks for the help?and I look forward to a nice stable setup!
I have a:
