Cold boot problem : P7P55D + G.skill 2*2Go PC10600 1333MHz
  • Cold boot problem : P7P55D + G.skill 2*2Go PC10600 1333MHz
    Here is my configuration :
    Model of the motherboard: Asus P7P55D (last bios version 1307)
    Model of the memory: G.Skill Extreme Series RL 4Go ( 2*2 ) PC10600 1333MHz Dual Channel F3-10666CL9D-4GBRL
    Model of the CPU: Intel I7 860
    No overclock, default settings in the bios.
    When the pc is cold I have blue screen or freeze and reboot on windows... I have to reboot about 10 times before I can use the PC.
    When the pc is cold memtest find a lot of errors with my RAM but when the pc is "hot" no more errors with memtest...
    Could you help me ?
    http://www.clipderap.com
    Please send those in for new replacements, and the new modules should not have a problem. Also with memory settings in BIOS, simply enable XMP Profile under "Ai Overclock Tuner" and the motherboard will detect and set everything automatically.
