I'm in the middle of planning a new computer ...
The new mainboard may be the MSI P55-GD65 with a i7-860 or 870.
I like to use two 4 GB modules in dual channel mode.
1. On Skill product site for the F3-12800CL9D-8GBRL I found the MSI P55-GD65 being listed. On the MSI-homepage I don't found this module. Does G.Skill had tested all the mainboards listed for a memory module?
2. Timing 9-9-9-24-2N, does the '2N' stand for the command rate? 2T for 4 memory modules (= 16 GB) and 1T for 2 modules (= 8 GB)?
Thanks for your answers
Juergen
Juergen
so I will update at first.
plus MSI GD65 plus 2x 4GB F3-12800CL7D-4GBRH @ 1955MHz
Hope this helps you too.
