GSkill Tech Support,
I am looking to purchase memory for the following system:
Gigabyte GA-P55M-UD4
Intel i7-860
The confusion surrounds the specs listed on your website for your products. Are those specs for the SPD (default) values or are they for the XMP profile values? After reading about 10+ pages of posts, it seems that the SPD values are slower and lower voltage than the XMP values. How can I determine what is what? For example:
F3-12800CL7Q-8GBECO is supposed to be a DDR3-1600 (PC3 12800), 7-8-7-24-2N, and 1.35 Volts part. Is this the SPD value or the XMP value? Can you tell me both values?
Thanks and regards, Peter
Intel i7-860
