Model of the motherboard: GA-790XTA-UD4 , bios F2
Model of the memory:F3-12800CL9D-4GBRL (2x2GB)
Model of the CPU:PHENOM II X4 955
OS: windows 7 64 bit
Crashes and freezes or screen goes blank. Got a windows memory error once, didn't write it down. Failed windows memory diagnostic tool a few times but always hung during test. Memstat86+ hangs as well.
Settings:
memory clock 8x 1600MHz
DCTs Mode: ganged
DDR3 Timing Items: Manual
CAS# latency: 9T
RAS to CAS R/W Delay: 9T
Row Precharge Time: 9T
Minimum RAS Active Time: 24T
1T/2T Command Timing: 2T
TwTr Command Delay: 6T
Trfc0 for DIMM1: 110ns
Trfc2 for DIMM2: 90ns
Trfc1 for DIMM3: 90ns
Trfc3 for DIMM4: 90ns
Write Recovery Time: 12T
Precharge Time: 6T
Row Cycle Time: 40T
RAS to RAS Delay: 4T
Do you have any suggestions?
Settings:
DCTs Mode: ganged
CAS# latency: 9T
Precharge Time: 6T
Row Cycle Time: 40T
