Cold boot with P7P55d and F3-12800CL9-2GBRL
  • Cold boot with P7P55d and F3-12800CL9-2GBRL
    I buy recently a new PC in a computer shop :
    -Corsair 550Vx
    -Asus P7P55D
    -Intel core I5 750
    -ATI HD4890 vapor-x
    -WD Black 1TO
    -2x2Go Gskill memory F3-12800CL9-2GBRL
    -Windows Ultimate x64 ( I also try the 32 bits version)
    I have cold boot problems and a BSOD the first time I turn the computer each day. I have to stop and restart the PC to make Windows run.
    I tried different RAM settings : AUTO, XMP and Manual but I still have problems
    I made a memtest and everything is ok.
    I have no problems when Windows run : every software and game works fine.
    What could I do to solve this ?
    Should I replace the RAM with a PC10600 model ?
    Here the cpuz images : http://picasaweb.google.fr/stecova/P7P55D#
    And my manual BIOS settings
    BIOS, Menu Ai Tweaker
    AI Overclock Tuner: Manual
    CPU Ratio Setting: Auto
    Intel Speedstep: Activated
    Turbo Mode: Activated
    Xtreme Full Power Mode: Auto
    BCLK Frequency: 160
    PCIE Frequency: 100
    DRAM Frequency: DDR3-1600Mhz
    QPI Frequency: Auto
    DRAM Timing: 9-9-9-25
    DRAM Timing mode : 2N
    CPU Voltage Mode : Offset
    DRAM Voltage : 1.50V
    Everything else Auto...
    Advanced / CPU configuration:
    -CPU Ratio Setting: Auto
    -CIE Support: Desactivated
    -Hardware Prefetcher: Activated
    -Adjacent cache lin prefetech: Activated
    -Max CPUID Value: Desactivated
    -Intel Virtualization Tech: Activated
    -Fonction TM du CPU: Activated
    -Execute Disable Bit Capability: Activated
    -Active Processor Cores: All
    -A20M: Desactivated
    -Intel Speedstep: Activated
    -Turbo Mode: Activated
    -C-State tech: Activated
    Stefan
    Go ahead and send those in for new replacements and the new set should solve the problem.
