F3-12800CL7D-4GBRH and M4A79T (atikmdag)
  • F3-12800CL7D-4GBRH and M4A79T (atikmdag)
    Motherboard: ASUS M4A79T Deluxe
    Memory: F3-12800CL7D-4GBRH
    CPU: Phenom II 965 C3
    I have this setup running at the moment, using the same timings as advertised except tCL set to 8 instead of 7, at 1600MHz
    Everything seems fine except 3dMark - it gives a TDR on atikmdag, even if i let the motherboard Auto the timings (which results in 1333MHz and slack timings)
    Any tips from G.Skill regarding good settings to use?
    Kind regards,
    After lots of messing about I removed one stick - no atikmdag errors, Vantage runs fine and anything else from Futuremark.
    Confusing issue that no matter what settings, I cannot run 2 sticks of this F3-12800CL7D-4GBRH, but pop one stick in and everything is fantastic?
    Would appreciate any input from GSKILL
      Very odd, send the memory in for new replacements. If you continue to have the same issue, you may need to get your CPU replaced.
        Thanks for the response.
        Can you confirm the settings for these 2 sticks on this motherboard? In case I have missed something!
          Memory Frequency DDR3-1600
          Memory Timings tCL 8 - tRCD 8 - tRP 8 - tRAS 24 - Command Rate 2
          Memory Voltage 1.60V
            Big thanks to G.SKILL, both for the memory and the A1 support - 2 new DIMMS fixed it pretty well
              cant edit, but note:
              8 7 7 7 27 1T
              impressive DDR
                Should be quite fast! =)
