F3-12800cl9d-4gbnq + gigabyte ga-ma790xt-ud4p bios setting guide please
  • F3-12800cl9d-4gbnq + gigabyte ga-ma790xt-ud4p bios setting guide please
    i need help with my F3-12800CL9D-4GBNQ ram im getting 1333 8-8-8-22 in my GIGABYTE GA-MA790XT-UD4P and its running at 1.60 volts and as far i know those are bad timing .... and thats what i see in everest software and this ram should be running at 1600 9-9-9-24 1.50 volts help me please my RIG is brand new i just build it like 4 days a go. i dont know that much about PC thats why i need some one to advice me how to set the right memory timings with out having any issues
    respond fast please
    here are my specs:
    phenom II x4 965 3.4ghz c3 processor
    gigabyte ga-ma790xt-4dup mobo
    xfx 5870 1gb gddr5 video card
    asus xonar d2 sound card
    1tb wd hard drive
    corsair h50 cpu cooler
    corsair 850w psu
    gskill 4gb F3-12800CL9D-4GBNQ 1600 9-9-9-24 ram
    help plesase GSKILL guys
    thanks
    Please help! I built a similar setup but used F3-12800CL9Q-8GBECO.
    My setup is
    AMD 965 Black AM3
    Radeon HD 4890 1GB
    Asus Crosshair iii formula MB
    1 tb hd
    Rosewill 950w ps
    I am also new at this and would like to know what issues I would run into running this.
    Jeremy
      any responses ??? any help ??
        Simply enter the BIOS and make the changes.
        DRAM Frequency DDR3-1600 (x 8 Memory Multiplier)
        Memory timings - tCL 9 - tRCD 9 - tRP 9 - tRAS 24 - Command Rate 2
        Memory Voltage - 1.60V
        Save and exit, and everything should be running smoothly. You can also enable the XMP profile to make the changes for you.
