Hi i brought and fitted two kits of Ripjaw 4GB(2x2GB)DDR3 F3-16000CL9D-4GBRH 2000MHz Dual Channel Ram,so now i have 8GB total in all four slots.
I have been getting the odd freeze or BSOD (in game only) while trying to set them up and i was wondering if anybody could help or give advice,im not sure what the max volts i can go up to on the ram and i know very little about overlocking so any help will be much appreciated.
Here are My specs and settings.
Intel Extreme Quad Core QX9770
2x Nvidia 9800GX2 (in quad SLi)
Thermaltake ToughPower 1500W PSU
2 x 150GB WD Raptors in RAID0
Vista Ultimate 64-Bit
All WaterCooled
Asus Striker II Extreme nForce 790i Ultra SLi
Bios settings *1203*
CPU Level Up = Auto
Memory Level Up = Auto
AI Overclock Tuner = Manual
CPU Multiplier = 8.0 (3.6ghz)
FSB - Memory Clock Mode = Linked
FSB - Memory Ratio = Sync mode
FSB (QDR) MHz = 1800
MEM (DDR) MHz = 1800
LDT Frequency = 5x
PCIE Bus Slot 1 & 2 MHz = 100
PCIE Bus Slot 3 MHz = 100
SPP<->MCP Ref Clock, MHz = Auto
SLI-Ready Memory = Disabled
Memory Timing Setting
P1 = Enabled
P2 = Enabled
tCL = 9
tRCD = 9
tRP = 9
tRAS = 27
CMD = 2T
** Advanced Memory Settings **
tRRD = Auto (6)
tRC = Auto (45)
tWR = Auto (12)
tWTR = Auto (19)
tFAW = Auto (29)
tRD = Auto (11)
tRTP = Auto (7)
tRFC = Auto (100)
tREF = Auto (7.8)
Over Voltage
CPU Voltage = Auto (1.32)
Loadline Calibration = Disabled
CPU PLL Voltage = 1.52v (1.53)
CPU VTT voltage = 1.30v (1.32)
Memory Voltage = 1.65v (1.67)
NB Core Voltage = 1.52v (1.54)
SB Core Voltage = 1.55v (1.55)
*DDR3 Termination Voltage = 0.83*
CPU GTL REF0 Ratio = Auto
CPU GTL REF1 Ratio = Auto
CPU GTL REF2 Ratio = Auto
CPU GTL REF3 Ratio = Auto
NB GTL REF Ratio = Auto
DDR3 CHA1 Ref Volt = Auto
DDR3 CHB1 Ref Volt = Auto
DDR3 CHA2 Ref Volt = Auto
DDR3 CHB2 Ref Volt = Auto
CPU Configuration
CPU Internal Thermal Control = Auto
Limit CPUID MaxVal = Disabled
Enhanced C1 (C1E) = Disabled
Execute Disable Bit = Enabled
Virtualization Technology = Disabled
Enhanced Intel SpeedStep(tm) = Disabled
CPU Core 2 = Enabled
CPU Core 3 = Enabled
CPU Core 4 = Enabled
Spread Spectrum Control
CPU Spread Spectrum = Disabled
PCIE Spread Spectrum = Disabled
MCP PCIE Spread Spectrum = Disabled
SATA Spread Spectrum = Disabled
LDT Spread Spectrum = Disabled
All WaterCooled
CPU Level Up = Auto
LDT Frequency = 5x
P1 = Enabled
P2 = Enabled
tCL = 9
tRCD = 9
tRP = 9
tRAS = 27
CMD = 2T
tRRD = Auto (6)
tRC = Auto (45)
tWR = Auto (12)
tWTR = Auto (19)
tFAW = Auto (29)
tRD = Auto (11)
tRTP = Auto (7)
tRFC = Auto (100)
tREF = Auto (7.8)
Over Voltage
CPU Configuration
