I've been running a couple weeks at 7-7-7-21 1t 1300, unganged, 1.65v, 8gigs. Rock solid.
Settings for F3-12800CL7D-4GBRH x2 + Crosshair III Formula + Phenom II x4 965
Really confused
If it is to set RAM frequency at 1333 MHz, is not it better to select a model among 10666 series, like F3-10666CL7D-4GBRH (7-7-7-21 2N) ?
Also is there a big differnce between 1N and 2N ?
Has the 1204 BIOS version solved the issue ?
Many thanks
Yes, if you would like to run CL7. Temporarily most AMD motherboards can not operate DDR3-1600 CL7 so CL8 must be used. In the future, the BIOS revisions should fix this issue which is what people are waiting on rather than purchasing a different memory package with a higher latency. Not to mention you could simply set the CAS Latency to 8.
There is definitely a difference between 1N and 2N, but not all motherboards will be able to operate 1N.
Regarding the BIOS revision, you will need to contact the motherboard manufacturer.
Many thanks
Technically there is a big difference between 1n and 2n, realistically, it is hard to tell. I could run some benchmarks and see how things play out when I get some time.
As soon as Asus posts a non-corrupt version of the 1204 bios, I will try it out.
Which RAM and which timing ?
Please, until the problem is hopefully solved by a BIOS update, can I still go for this RAM model ? Then is it better to set it @ 1333 MHz 7-7-7-21 2N or @ 1600 MHz 8-7-7-24 2N ?
Nobody has tested the 1204 BIOS (must be downloaded with IE and not FF) ?
I expect that you can go with this model and use 1333 7-7-7-21 1T (how I have mine set). Then again with all four banks filled, there is a little less give with the timings.
I'll have to try downloading the bios with IE, but that would be a weird issue if it is the case.
I set up my system and, as expected by this thread, got RAM problems.
First my system is not stable (50% W7 will reboot after a BSOD during starting up of the machine) when using the default BIOS setting viz. 9-9-9-24-1T @669 Mhz !
I set the RAM frequency to 800 Mhz (dafault timing are 11-11-11-29-1T) and the machine has become more stable.
If I set the theoretical chip timing (7-8-7-24-2T @] 800 Mhz) the system will not boot (BIOS ask me to press F1 after reset for failed overclocking).
The same thing with timing recommended at the beginning of this thread (8-7-7-21-2T) no boot
My system boots at 8-8-8-24-2T.
If I run memtest86+ with this timing I however get many errors (9000+) for test #5.
My system is using the latest BIOS 1204.
Have I faulty RAM ?
Memory always needs to be manually set now since they are much above the standard. So if you simply plug them in, do NOT expect them to run smoothly.
Try testing each stick individually with the proper settings. If you could, post up screen shots of your BIOS so I can see if you have anything set incorrectly.
I tried each stick individually and found that only one is faulty. So I did a new series of tests with the "good" stick and memtest86+4.00 @800MHz.
7-8-7-24-2T: no boot (failed OC)
8-7-7-21-2T: fails test#5
8-8-8-21-2T: test OK (7-pass test)
Yes I checked the memory is auto-configured as un-ganged. I manually set the voltage to 1.6V.
Note that my model is F3-12800CL7D-4GBRM (the blue ones).
Shall I link my screen shots on a personal web site ?
Please is there an official GSkill support to tell me whether I should RMA the sticks ?
