BIOS settings for F3-10666CL7D-4GBRH on a M4a79xtd evo MOBO
  • BIOS settings for F3-10666CL7D-4GBRH on a M4a79xtd evo MOBO
    Hi, my mobo auto-sets the timers to 9-9-9-24, i just want to know how to change so it can run at the advertised timings of 7-7-7-21.
    Also, can you recommend me a diagnosis tool for DDR3 memory? just want to check if it has errors or not.
    Thanks in advance.
    Instead of AUTO, simply enter teh timings manually.
    tCL - 7
    tRCD - 7
    tRP - 7
    tRAS - 24
    Command Rate - 2
    Memory Voltage - 1.5V
    Memtest is a very good diagnostic tool that you can download for free.
      Just a quick doubt, why tRAS at 24 instead of 21 ? ( as advertised in newegg http://www.newegg.com/Product/Produc...82E16820231276 )
        My mistake, it should be 21.
