Maximus III Formula and F3-16000CL9D-4GB Ripjaws
  • Maximus III Formula and F3-16000CL9D-4GB Ripjaws
    Need some help on this one as I'm stumped....
    My setup is
    200 BCLK x 20 for 4.0GHz running ram currently at 1600 7-7-7-20 and I get decent bandwidth BUT if I wanted 1600MHz ram I would have bought it.
    If I set ram to 2000MHz 9-9-9-27 with my IMC at 1.39 and ram at 1.65 I can pass memtest all day long but once into Windows I error instantly on a prime run.
    So as my frustration has got the best of me I need some clear thinking advice on how to get my ram to 2000MHz
    AI Overclock Tuner:Manual
    OC From CPU Level Up:Auto
    OC From Memory Level up:Auto
    CPU Ratio: 20
    Intel Speed Step: Disabled
    BCLK Frequency:200
    PCIE Frequency:102
    Dram Frequency: DDR3-1600MHz @ 7-7-7-20
    QPI Frequency:6407MHz
    CPU Clock Amplitude: Auto
    PCH Clock Amplitude:Auto
    CPU Clock Skew:Auto
    PCH Clock Skew:Auto
    Extreme OV: Disabled
    Full Phase Control:Full Phase
    Load Line Calibration:Enabled
    CPU Voltage Mode:VID
    CPU Volts: 1.35
    CPU PLL:1.80
    IMC:1.39
    PCH:1.046
    Dram:1.65
    Dram Data Reff Voltage Chan A: Auto
    Dram CTRL Reff Voltage Chan A: Auto
    Dram Data Reff Voltage Chan B: Auto
    Dram CTRL Reff Voltage Chan B: Auto
    Intel i7-860@4.0GHz FPO L930B518
    Asus Maximus III Formula (Bios 902)
    G.SKILL F3-16000CL9D-4GB
    Diamond 4870X2 XOC
    2x160GB WD Raid0
    Creative X-FI
    Corsair HX620
    HeatKiller 3.0, Koolance VID-487X2, PA120.3
    Win7 Ultimate X64 Retail
    RCA 32" LCD (1360x768)
    I'm curious...the fail in Prime sounds more like a CPU difficulty rather than a memory problem. Can you reduce your CPU ratio a step or two and retest Prime leaving your RAM at 2000? CPU ratio won't affect the RAM speed. Correct me if I'm wrong. And I'm not a tech, just bored for the moment.
      Use these settings:
      CPU Ratio: 17
      BCLK Frequency:167
      PCIE Frequency:102
      Dram Frequency: DDR3-2000MHz @ 9-9-9-27
      QPI Frequency:Auto
      CPU Clock Skew:Auto
      PCH Clock Skew:Auto
      CPU Volts: AUTO
      CPU PLL:1.90
      IMC:AUTO
      PCH:AUTO
      Dram:1.65
      Once this works, then work on voltages and overclock.
        the cpu passes all day long with the ram at 1600MHz blend or small fft's even linpak passes, once ram is moved to 2000MHz prime fails blend test.
        So this is a ram/IMC related issue cpu is not the culprit.
        Use these settings:
        CPU Ratio: 17
        BCLK Frequency:167
        PCIE Frequency:102
        QPI Frequency:Auto
        CPU Clock Skew:Auto
        PCH Clock Skew:Auto
        CPU Volts: AUTO
        CPU PLL:1.90
        IMC:AUTO
        PCH:AUTO
        Dram:1.65
        chip is stable @ 4.0GHz my oc is not the problem the ram will not run at rated speed on this overclock others have the same problem as me with different board so it is not bios related, I should not have to downclock my CPU to run the ram at rated speeds unless I missed the memo.... I see no reason to run QPI on auto unless you can give a valid reason too.
        Corsairs run 2100MHz easy with 1.55volts my ripjaws fail 1600MHz@ 1.55 volts and the jedec says they should run at that voltage, so I can assume this kit is not rated for 2000MHz unless you run the CPU at stock speeds
        Diamond 4870X2 XOC
        2x160GB WD Raid0
        Creative X-FI
        Corsair HX620
          OK...misunderstood. Here's another resource for you in case you haven't seen it.
          http://www.bit-tech.net/hardware/cpu...-core-i5-750/4
            To be exact, it is simply a BIOS setting issue.
              thanks for the link
              I'm not trying to be rude, please understand I'm just frustrated but your response is a little BS for being a rep of said ram...
              Clearly I'm well a ware its a bios setting thats why I'm here asking for help
              unless the divider is broken the ram should work at 2000MHz with my current settings, if I'm missing something please feel free to educate me
              Diamond 4870X2 XOC
              2x160GB WD Raid0
              Creative X-FI
              Corsair HX620
                I apologize if I came off rude, but I just wanted to state that the settings you originally had them at are not optimum for your setup. The 860 processor does not like the 10X memory multiplier and depending on your motherboard BCLK 200 may be an issue as well which is why I gave you slightly different settings.
                I am here to help you get your computer running properly, I have the exact setup, so we will be able to get it working properly. Simply try the settings I provide and report the results and I will be able to troubleshoot the issue. =)
                  ok I will run your suggested settings and report back
                  If I sounded rude I apologize as well, I'm just stumped on this one, ram overclocking was never a problem for me on 775 seems there is a learning curve for 1156
                  Diamond 4870X2 XOC
                  2x160GB WD Raid0
                  Creative X-FI
                  Corsair HX620
                    Ram is stable at 2000MHz finally.
                    Once the XMP profile was enabled in teh bios and overclock settings dial'd in the ram passes 6 hours of prime and 20 loop IBT
                    AI Overclock Tuner: XMP
                    Xtreme Memory Profile: [Profile 1]
                    CPU Ratio: 20
                    BCLK Frequency: 200
                    PCIE Frequency: 102
                    QPI Frequency: 6407MHz
                    CPU Clock Amplitude:Auto
                    CPU Clock Skew:Auto
                    PCH Clock Skew:Auto
                    Full Phase Control: Full Phase
                    Load Line Calibration: Enabled
                    CPU Voltage Mode: VID
                    CPU Volts:1.35
                    CPU PLL:1.90
                    IMC:1.39
                    PCH:1.046
                    Dram:1.65
                    Diamond 4870X2 XOC
                    2x160GB WD Raid0
                    Creative X-FI
                    Corsair HX620
                      Glad to hear it worked out. We enjoy overclocking as well, but when we're trying to troubleshoot the issue it's just easier to minimize possible faults, which is why I wanted to revert some settings. You should enjoy that fast setup. =)
