Try this setting:
CPU Clock Ratio - 20x for 3.6GHz
QPI Link Speed - AUTO
Base Clock Control - Enabled
BCLK Frequency - 180
System Memory Multiplier - 10
Uncore & QPI Features
Uncore Frequency - 3600
CAS Latency Time - 7
tRCD - 8
tRP - 7
tRAS - 21
Enter these for the other three as well.
Channel A Timing Settings
Advanced Timings
tRC - 27
tRRD - 4
tWTR - 4
tWR - 8
tRFC - 60
tRTP - 4
tFAW - 20
Command Rate - 1
Round Trip Latency - 42
Advanced Voltage Control
Load-Line Calibration - Disabled
CPU Vcore - 1.35V
QPI/VTT Voltage - 1.600V
CPU PLL - 1.900V
PCIE - AUTO
QPI PLL - 1.400V
IOH Core - 1.400V
ICH I/O - 1.600V
ICH Core - 1.300V
DRAM Voltage - 1.640V
Rest to AUTO
Should be able to get DDR3-1800 range. Then try lowering timings as low as possible. That motherboard should be able to handle BCLK 180, it gets sensitive once you near 200.
tRCD - 8
tRP - 7
tRAS - 21
Advanced Timings
tRC - 27
tRRD - 4
tWTR - 4
tWR - 8
tRFC - 60
tRTP - 4
tFAW - 20
Command Rate - 1
CPU Vcore - 1.35V
CPU PLL - 1.900V
PCIE - AUTO
QPI PLL - 1.400V
IOH Core - 1.400V
ICH I/O - 1.600V
ICH Core - 1.300V
Rest to AUTO
