Looking to populate an HP Z420 workstation and would like to use
[RipjawsZ] F3-14900CL10Q-32GBZL
The HP Z420 spec say to use 14900E memory (DDR3-1866 unbuffered)
Beside a lot more expensive And the ECC
Is there any other difference between
PC3-14900E and PC3-14900
Are they interchangeable (AKA can I use non ECC if it used in just a workstation and not a network server?)
In other words (loaded question) Is GSkill memory sufficiently 'error-free' to not need the ECC capability?
