Supported by Socket 1150 Memory Model F3-17000CL9Q-16GBXM
  • Supported by Socket 1150 Memory Model F3-17000CL9Q-16GBXM
    Hello. I'd like to go from 8Gb of gskill 1866 ram and upgrade to 16 GB. I have an ASrock Z77 motherboard which seems to be very versatile and supports up to 2133 ram. Is the Memory Model F3-17000CL9Q-16GBXM set compatible? Specs seem more leaned toward socket 1155. Would it also work on a socket 1150 if i change to a newer motherboard in the future? If not id like to know a great set that would work on my board with low CAS and 16GB. Thanks!
    Yes, no problem, it is a perfect fit.
