Hello to all,
I just bought this kit: F3-2133C9Q-32GTX
I installed it on the following system:
MB: Asus Z97 PRO
CPU: Intel i7-4790K
VideoCard: Nvidia GTX 970 4GB
The problem only occurs when I put together all 4 memory sticks.
The system fails to boot.
To be more precise, as soon as I press the power on button the fans starts spinning, I can see some digits changing frequently on the onboard debug display, and after a few seconds it shut down and restart in a loop (no beep at all).
I can't even see anything on the monitor, let alone entering the bios.
So I can't check XMP settings or anything else.
If I put only 2 memory sticks (on the appropriate slots) the system powers up correctly.
I can enter the bios, set the XMP settings and logging into Windows 8.1.
But again if I put all 4 sticks together the system refuses to boot.
I was thinking about an insufficient power supply from the PSU, that is a CoolerMaster 700W SilentPro.
Checking on internet I've seen that giving my setup I should need aroud 450W only, so I suppose it's not an issue here.
EDIT: I just experimented a bit.
Testing each memory stick individually they work fine, so I think it's not a defecting kit.
Testing each slot individually and in pair they work fine too, so I think it's not a defective motherboard either.
On the QVL for this memory kit and my motherboard is listed.
Thank you for your support,
Max
MB: Asus Z97 PRO
CPU: Intel i7-4790K
Max
