what g.skill ripjaws???
  • what g.skill ripjaws???
    This is my first post on here, so hi all! And be gentle.
    I am in the process of upgrading my gaming rig, so far I've got an Amd 9370 cpu, Asus sabertooth 990fx r2.0 mobo, corsair h80i cooler and some old ripjaw 1333mhz ram.
    On with my issue, the mobo can run up to 2400mhz ram duel channel ddr3, the cpu can handle 1866mhz duel channel ddr3. Although I have seen on the Internet people with this combo running well above 1866mhz.
    My old ram has never let me down, hence why I want more. What would you guys suggest?
    All help very much appreciated.
    Sorry I should of added that I currently use ripjaw 8gb 4*2gb sticks 1333mhz and would like 16gb 2×8gb sticks at 1866mhz or higher.
    I'm getting myself in a right muddle with what the mobo can handle and what the cpu can handle.
      http://www.newegg.com/Product/Produc...-623-_-Product
        Thank you for the quick reply, does it have to be trident x or could I use ripjaws x?
          Trident X is the best, but you can use RipJaws X too
