G-Skill Sniper F3-12800CL9Q-16GBSR
  • G-Skill Sniper F3-12800CL9Q-16GBSR
    Hello all!
    Can someone tell me what the maximum Overcloking of this memory can go on x79 platform?
    Depends on the CPU and how well you can overclock. DDR3-1866+ is no problem at all.
      over
      Hello, thanks for reply
      My system is:
      Asus Sabertooth x79- CPU Intel Corei7 3820 - XFX R9 290X- Samsung Serie 5 LCD 32p - G.SKill Sniper 16GB 1600MHz - Speaker Bowers & Wilkins mm1 - PSU Corsair 750 - 2 SSD OCZ Agility 3 Raid0 e 1 Seagate 500gb- Microsoft desktop - wireless laser 5000
      my attempts were:
      9-10-10 1.6v @2133 No boot
      10-12-12-31-2N 1.5v @ 2133 No boot
      Any suggestions ?
        11-11-11-30 or 11-12-12-31 1.60V and see how that works.
          Hello
          Hello Admin!
          well not work too
          Try here
          11-11-11-30 1.60@2133 (Start Post on, but freeze after)
          @1.65v idem
          11-12-12-31 1.60V@2133 same thing
            Did you boot VCCSA Voltage? May be it needs a boost for DDR3-2133. Is DDR3-1866 stable?
              I didn“t try 1833 only 2133
              Not boost VCCSA too. Maybe need to rise them? How much? 0.5v ?
                Try DDR3-1866 first to see if that can work.
                If it can, then try raising VCCSA +0.05V or +0.1V to see if it can be stable at DDR3-2133.
                  Ok, I will try
