Hello
I've been running a F3-14900CL9D-8GBSR 2x4GB kit for a while now and figured one can always use more memory so I bought the same kit for the second time. However these two kits (a F3-14900CL9D-8GBSR and a F3-14900CL9D-8GBSR) don't seem to be working together at all. My previous motherboard with a 990FX could detect them all at the same time but only could use the 8GB and my current motherboard with a Z87 won't even boot with both kits installed. Both kits work individually, but not together, so there really isn't a reason for an RMA either.
I did try running them @ 1600MHz and even 1066 on the AMD with no improvement but since I can't even get to UEFI with the Intel I'm guessing there isn't much to do?
