help ram settings possible
  • help ram settings possible
    hey i just got a new system and it kept shutting down until i got the ram timings in. atleast i assume that was the issue. but i wanted to make sure i got everything configured correctly.
    i have the:
    Asus sabertooth 990fx board
    amd fx-9590 black unlocked
    gskill ripjaw SDRAM DDR3 1866 F3-14900CL10S-8GBXL (2 sticks of these)
    anyway i set the timing 10-11-10-30 1.5v 2t and ddr 1866. anymore settings to help performance and sustain?
    Timings look good.
    Is the system stable?
      As of now it seems to be stable. When the bios loaded the default settings as soon as my comp had a load it would shutdown and I would have to reset it with the jumper. When I input the settings above it seems to be stable. I just wanted to make sure the timings and settings are 100% accurate. Is there any additional recommendations on settings you would use? Thanks in advance
