Greetings,
I'm probably going to go with the Asus PX79 WS motherboard. QVL compatible list is here: http://dlcdnet.asus.com/pub/ASUS/mb/...QVL_140114.pdf
Asus QVL list shows the following G.Skill 64GB kit as compatible: F3-1866C10Q2-64GZM
Newegg sells this kit but seems to be out of stock and I don't know if they're going to get anymore? (http://www.newegg.com/Product/Produc...82E16820231711)
I'm wondering if one of the higher Z series such as the 2133 or 2400 would work? (http://www.newegg.com/Product/Produc...82E16820231713 or http://www.newegg.com/Product/Produc...82E16820231715) or if I should stick with the 1866mhz 64 GB compatible kit on the QVL list? Would the higher kits work possibly but need to be ran at lower speed/voltage?
