I recently purchased a 4x4GB kit from you with which to upgrade a PC, and am having some difficulty getting it to function. Some relevant details:
RAM kit: F3-12800CL9Q-16GBRL (4x4GB Ripjaws series) Serial numbers 140525000277999 through 8002
Motherboard: Asus P7P55D-E
CPU: Intel Core i3, 2.93 Ghz
I have tried this on two separate PCs with the same mobo/CPU combination. They each originally had one of the following kits:
G.Skill Ripjaws: F3-12800CL9D-4GBRL (2x2GB)
G.Skill Ripjaws: F3-12800CL9D-8GBXL (2x4GB)
The motherboard is listed on your compatibility list for the new kit. I have have tried the following configurations:
-One DIMM in slot A1 -- posts fine, but halfway through windows load I get a blue screen with IRQL NOT LESS OR EQUAL (0x0A), suggesting faulty hardware. This occurs with every stick in the new kit; the old RAM will boot successfully with only one stick installed this way.
-Two DIMMS, A1 & B1 -- same as above (this is the current working configuration, with the old kit)
-All four -- does not post. Hangs at the splash screen indefinitely.
(( for reference, the DIMM slots are numbered A2-A1 B2-B1 starting from the nearest to the CPU ))
I have tried running the windows memory diagnostic tool for each of the four sticks individually, as well as several 2x and 4x configurations, and none of the tests will complete. After leaving the test running for ~30min, no progress had been made (by comparison, the working RAM kit takes about 6-8 minutes to fully complete the test). The tool appears to freeze immediately, since I am unable to access the "settings" option.
On overclock.net I found a help post with a similar issue, in which the user resolved the problem by installing his kit sequentially by serial number. I've tried this, with no success:
http://www.overclock.net/t/1273610/4...stem-wont-post
I have additionally verified that the voltage and timings in the BIOS match the RAM specs -- these are the same across both the new and old kits.
A G.Skill tech responded to an email I sent regarding this issue, suggesting that I underclock the RAM to 1333 with 8-8-8-24 timing in the BIOS, since some i3 CPUs can't handle 1600. I tried this, with no change in the above-listed results.
All this suggests to me a defective kit and I should just go straight to RMA, but I have a hard time believing that all four sticks are bad. Is there anything else I'm missing?
