Asrock Z87 Extreme4 + F3-1866C9D-16GXM - single channel only
  • Asrock Z87 Extreme4 + F3-1866C9D-16GXM - single channel only
    Hello.
    My setup:
    Asrock Z87 Extreme4
    Intel i7 4770 (non K)
    16GB Ripjaws X F3-1866C9D-16GXM
    Every time I set the memory to Intel XMP values (1866Mhz 9-10-9-28) it works only in Single Channel mode. If I set it to 1600Mhz, it works in dual channel mode, but with timings 11-11-11-29. I have tried to set the DRAM voltage to 1.55V, but nothing changed.
    I would like to know if it is happening because my processor is a non-K, or if I'm doing something wrong.
    Thank you.
    Double check installation, make sure you have the latest BIOS, reset BIOS and try again. That is a strange problem, if two modules are installed it should be dual channel no matter what frequency.
