I am considering buying 2 kits of this memory G.SKILL F3-2400C11D-8GXM at 2400MHz, for a total of 16GB (4x4GB).
1) Is it compatible to my Z77 Asrock Pro4-M + Intel i5 3570K ?
2) I am planning to run this memory at 2133MHz in order to tighten up the latencies and reduce the stress on the IMC. Is it a good practice?
3) I keep reading in forums that using 4x4GB memory puts a stress on the IMC. Can someone explain technically why this happens? As far as I can imagine, accessing RAM using 2 (dual) channels would be less stressing as the load is shared.
4) How do I ensure that the 2 kits I buy are "factory-matched" ?
Thanks!
Thanks!
