I have a memory upgrade dilemma, hopefully I can get some advice.
I'm currently using a gigabyte p55-ud4p rev 1.0 motherboard with an i7 860 water cooled CPU. I have 4GB of Ripjaws f3-16000cl9d-4gbrh memory and would like to expand to at least 8 gb. I use moderate over clocking, mostly for gaming and a little video and photo editing. The motherboard supports up to 2000 MHz ram.
I'm considering the following options. Ideally I'd like something compatible with my current ram, but would use just new ram if it meant a significant performance increase. Eventually I will upgrade my CPU and motherboard (maybe in a year or so), and it would be nice to get something I could carry forward.
Ripjaws F3-10666CL7D-8GBRH
Ripjaws Z F3-2400C10D-8GZH
Trident X F3-2400C9D-8GTXD
How likely is it that the first option could be used with my existing RAM? What kind of performance might I get from the newer Ripjaws or trident at 2000 MHz? Is there another option I should consider?
Thanks!
Thanks!
