I will be putting together a system with amd fx 9370 cpu and asus crosshair v formula z motherboard. I would like to use 16GB of memory in 2x8GB configuration, but don't see anything from G.SKILL on the QVL on asus support website for that board in 16GB 2x8. Can anyone help me out with a recommendation in the $150-$200 range from newegg?
memory compatibility/recommendation
Most of the DDR3-1866 2x8gb kits have at least one or two 990FX mainboards from ASUS, including the original CVF, in their official QVL:
http://gskill.com/en/product/f3-14900cl10d-16gbxl
http://gskill.com/en/product/f3-1866c9d-16gxm
http://gskill.com/en/product/f3-1866c9d-16gsr
http://gskill.com/en/product/f3-1866c9d-16gzhTeam HardwareLUXX | Show off your G.SKILL products!
Here is a great kit:
http://www.newegg.com/Product/Produc...82E16820231623
Perfect for that motherboard and CPU in every way.
