Hi, I was running 4 sticks of ram for around 4 years and just found out some of it was bad causing BSODs. I could sure use some help deciding if I should just order 4 new sticks of the same or, maybe something that would be better. I used MEMTEST to find the faulty ram. Here is my motherboard/ram I'm using now. Thanks!
http://www.gigabyte.us/products/prod...65&dl=1#driver
http://www.newegg.com/Product/Produc...82E16820231193
