Okay I'm completely new to this, but figured I built my first rig in a few years and might try to beef it up a tad
ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Intel Core i5-3350P Ivy Bridge 3.1GHz (3.3GHz Turbo) LGA 1155 69W Quad-Core Desktop Processor BX80637i53350P
2 x G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-
I realize having 2 diff packs of memory to get to 16 isn't ideal for bumping the memory, but figured I'd give it a try. It all works at correct timings and at 1600 MHz just using the xmp profile. been in system about a week and a half and is very stable and cool so I'm not opposed to a little voltage jump. My question is even when I turn nearly everything to manual I can't adjust the timings, they are there to be altered but whenever I change one it goes back to 9. what am I doing wrong and if I get that part figured out what settings other than trying to drop the first 9 to 8 and 1n should I change?
