It's been months I was trying to stabilize my config.
I've finally managed and decided to share with you what I had to do to.
The motherboard is a P5E3 Pro, RAM is F3-12800CL7-4GBXM (Ripjaws X - 2 sticks of 4Gb).
The problem that a lot of people were experiencing was being unable to stabilize the system with 8gb of DDR3 - 12800.
I have managed to stabilize it 24h without errors Prime95 blend as well as HCI memtest (24hours too).
i'm running a QX9650 @ 400 x 9.
Here are the BIOS settings I have found to achieve this, after months of tweaking !
I really hope this will help someone out there.
Ai overclock tuner : [Manual]
CPU ratio : 9
FSB Strap to Northbridge [400]
PCIE Frequency [100]
DRAM Frequency [DDR3 - 1600 Mhz]
DRAM Command Rate [Auto]
DRAM CLK Skew Channel A [Auto]
DRAM CLK Skew Channel B [Auto]
DRAM Timing Control [Manual]
CAS Latency 7
RAS to CAS 8
RAS Pre Time 8
RAS Act Time 24
RAS to RAS Delay [Auto]
REF Cycle Time [Auto]
Write Recovery Time [Auto]
Read to Write [Auto]
Write to read S[Auto]
Write to read D[Auto]
Read to Read S [Auto]
Read to Read D [Auto]
Write to Write S [Auto]
Write to Write D [Auto]
Dram Static control [Auto]
Dram Dynamic write control [Auto]
Ai Clock Twister [Auto]
Ai Transaction Booster [Auto]
CPU Voltage [1.33750]
CPU PLL Voltage [1.50]
FSB Termination Voltage [1.20]
DRAM Voltage [1.50]
NB Voltage [1.37]
SB Voltage [Auto]
Clock Over Charging Voltage [Auto]
Load line Calibration [Auto]
CPU GTL Voltage [Auto]
NB GTL Voltage [Auto]
PCIE Spread Spectrum [Auto]
CPU ratio : 9
CAS Latency 7
RAS to CAS 8
RAS Pre Time 8
RAS Act Time 24
DRAM Voltage [1.50]
NB Voltage [1.37]
SB Voltage [Auto]
